I finally opened up my Harbor Freight freebe. There’s no adjustment. There’s also no fuse holder. But it seems to have a tiny fuse soldered to the board.
I know that some of the free/cheapy HF meters have a backlight and advertise ‘fused’. They are usually $1 more cost, when not free. I have at least 1 of each, backlight and a couple not, but all of them have fuses and pots. Just got a fused non backlite with pot HF dmm last week. Maybe I got some old stock…?
They don’t make them like they use too… lol
Many of us will mistakenly put voltage/amperage into the ohms mode circuit, won’t that little on board non replaceable fuse pop…?
How is the accuracy/calibration of these no pot, no fuse HF dmm…?
Technically, it’s not from HF. It was sent to me by VDC Electronics as a free gift after purchasing one of their BatteryMINDer battery chargers/maintainers. Must have been 2-3 years ago.
I got mine 4 months ago. As far as accuracy, it’s pretty close when measuring 120 volt AC outlets, but like the picture I posted comparing it to my Fluke 289, it’s off a bit. What reads 4.2 volts on the Harbor Frieght, reads 4.15 volts on the Fluke.
I’d gladly give it away but it wouldn’t be worth the shipping.
I measured four 18650 batteries with a UNI-T UT139C DMM, and found them all at 8.04V.I put them in my LiitoKala 500,and I saw 8.21V.
What do you suggest?
Edit.
When the charging was finished,the charger wrote 4.22V,the DMM 4.216V,and there were taken 317mAh from the charger.
I thought mine was defective, as it was charging cells to 4.24-4.25 and I was afraid a cell might vent. But as I read in this thread, it might be just fine?
I am kinda confused Theodore…….
8.04V / 4 batteries = 2.01V for each battery, measured on the DMM
8.21V / 4 batteries = 2.0525V for each battery, measured on Lii-500
I guess my first question is how or why were they discharged that low?
Pete7874, quoted below; may have the best suggestion of what to do next.
What was the voltage when you removed them from the charger and checked then with the DMM?
:person_facepalming: :person_facepalming: … You busted my chops ‘allcool’, at first glance I thought the “JK” was in your signature line. :person_facepalming:
I had googled “metric voltage” a couple of times… with no result of course; before I realized the “JK” was not in the sig line.
Personally, I hopes he checks in and clarifies what he said… at least to me. Cause I seem to be lost…………. :person_facepalming: …
Mea culpa.It was 4.04V,(for every one of course),not 8.04.
I charged them for measuring my TN40S ,which has returned to me by giorgoskok having bypassed the 4 springs.
Is there any way to calibrate the charging voltage on a Lii-500?
Mine reads about .4v high so when it terminates at 4.2v it’s really only 3.8v according to every other voltmeter I have.
Fine for a storage charge but useless otherwise.
Tomtop gave me a 50% refund but didn’t like my 50% review.
(said it was too harsh)
I’d like to try to fix it rather than just throwing it away.
