Conrad energy LiIon 9V 500mAh (Blue)
/DSC_9897.jpg)
Official specifications:
Chemistry: Lithium
Rechargeable: Yes
Voltage: 7.4V
Rated Capacity: 500mAh
Minimum Capacity: 450mAh
Voltage at end of discharge: 6.0V
Charging voltage: 8.4V
Internal Impedance: <500mOhm at 1kHz
Standard charge: CC/CV 8.4V 0.2C with 0.02C cut-off
Fast charge: CC/CV 8.4V 0.5C with 0.02C cut-off
Maximum continuous charge: 1C
Standard discharge: 0.2C to 6.0V
Fast discharge: 0.5C to 6.0V
Maximum continuous discharge: 1C
Operating temperature range: charge: 0°C ~ 45°C, discharge: –20°C ~ 60°C
Storage temperature range: less than 3 months: –20°C ~ 40°C, less than 1 year: –20°C ~ 25°C
Cycle life: 500 cycles to 70% using standard charge/discharge
Size maximum: 48.5 x 26.5 x 17.5 mm
/Conrad%20energy%20LiIon%209V%20500mAh%20(Blue)-info.png)
The German company Conrad have some 9V LiIon cell in their range of batteries, this is the high capacity version.
Overcharge protection on the A cell kicks in at 8,49 volt and over discharge protection at 5,67V
Overcharge protection on the B cell kicks in at 8,51 volt and over discharge protection at 5,56V
/DSC_9057.jpg)
/DSC_9899.jpg)
/DSC_9900.jpg)
/DSC_9901.jpg)
/DSC_9902.jpg)
/DSC_9903.jpg)
/Conrad%20energy%20LiIon%209V%20500mAh%20(Blue)-Capacity.png)
There is some difference in capacity between the two cells. Both cells handles load fine, even at 500mA, the capacity is also more than rated.
/Conrad%20energy%20LiIon%209V%20500mAh%20(Blue)-CapacityTime.png)
/Conrad%20energy%20LiIon%209V%20500mAh%20(Blue)-CapacityTimeHours.png)
/Conrad%20energy%20LiIon%209V%20500mAh%20(Blue)-Energy.png)
/Conrad%20energy%20LiIon%209V%20500mAh%20(Blue)-Charge.png)
Conclusion
These batteries have more than double capacity compared to NiMH 9V batteries and are close to a alkaline battery at low load and this battery will maintain high capacity and voltage at high load.
In moderate to high load situations this looks like a good replacement for alkaline.
Notes and links
Compare to other 9V batteries: Alkaline/NiMH/Lithium/other
