DMM UNI-T UT210E
This is a cheap clamp meter with DMM function.
It included the DMM, a pair of probes, a pouch and a manual (Both a English and a Chinese version).
The probes has removable tip covers.
The probes are rated for 10A, but it is not important for a clamp meter.
Display
The above picture shows all the segments on the display.
The circle with the arrow indicates auto power off, holding down the SELECT button during power on will disable that.
Typical display during usage, it will show the number and what measurement is selected.
When using the NCV function the display will show a number of -, depending on the electric field. This can usual be used to see if a mains outlet or cable is powered or trace a cable that is just under the wall. This function is always a guideline and not a 100% confirmation of voltage or no voltage.
Functions
Buttons:
Select/VFC (Blue): Will select secondary functions, holding down the button will enable a low pass filter for AC measurement (VFC).
Zero: Save the current measurement and show the following measurements relative to that value (Very important for DC clamps).
Hold (Yellow): Freeze the display, hold down to turn background light on.
Rotary switch:
Off: Meter is turned off
V: Show voltage, use the blue button to select between AC and DC
Ohm: Resistance, continuity, diode and capacitance
2A: Measure current with the clamp, use the blue button to select between AC and DC. Zero must be used on DC range
20A: Measure current with the clamp, use the blue button to select between AC and DC. Zero must be used on DC range
100A: Measure current with the clamp, use the blue button to select between AC and DC. Zero must be used on DC range
NCV: Non contact voltage. Any AC field near the clamp will be indicated.
Input
The two socket is used for V, Resistance, continuity, diode and capacitance
The clamp is used for all current measurements and for NCV. There is a red led at the bottom of the clamp to show when voltage is detected with the NCV function (Buzzer will also sound).
Measurements
Volt and frequency
AC volt can measure up to about 2kHz (RMS will not work at the frequency).
AC volt with VFC reduces bandwidth to 400Hz and limits range to 200.0V & 600V
All ranges starts on AC
Input impedance is 10Mohm to 11Mohm on AC and DC
Buzzer sounds on over voltage (600V)
Current
Buzzer sounds on over current (100A).
As usual clamp meters are not very precise and at 0.5A and 5A it was about 2% out.
Ohm, Continuity, diode and capacity
Ohm is 1V open and 0.33mA shorted
Continuity is fast (Below 4ms).
Continuity beeps when resistance is below 50ohm.
Continuity is 1V open and 0.33mA shorted
Diode range uses 3.3V, max. display is 2.2V at 0.5mA, max. current is 1.4mA shorted
11000uF takes about 9 seconds to measure.
Miscellaneous
Current consumption of meter is 7.2mA (13.2mA with backlight) in current mode
Current consumption of meter is about 1.7mA (7.7mA with backlight) in other modes.
Meter works down to 2.2V where it turns off, battery symbol show at 2.5V.
Backlight only works down to about 2.6V where it is fairly dim.
Both current and voltage readings are stable with changing battery voltage.
The meter usual need a couple of display update to reach the final value.
Viewing angle is good.
Display updates around 3 times/sec
Backlight will automatic turn off in about 15 seconds.
Will automatic turn power off in about 15 minutes.
Weight is 174g without accessories, but with batteries.
Size is 174 x 62 x 32mm
Probes & clamp
Probe resistance 37mOhm for one.
Probe wire is 90cm long.
Clamp can handle up to ø17mm
A look at the capacity measurement waveform.
Tear down
I had to remove two screws to open the meter.
The circuit board is carefully made to fit inside the meter and use all aviable space.
I assume the green wire is the NCV sensor
The circuit board has some input protection with two PTC’s and 3 MOV’s. The input resistors (R37A, R37B, R37C, R37D: 4x2.5Mohm) is split into 4 resistors, between these resistors and the input is a PTC.
Close to the MOV’s is a EEPROM (IC2: 24C02A) for parameter storage and some calibration, there is also trimpots for calibration.
There is a voltage clamp made with two transistors (Q4, Q9), it is not directly connected to input or output resistors but is probably switched in depending on range.
The big IC (DM1106EN) is the main multimeter chip and the frontend for the clamp is mounted close to it (U4:OPA4330 Quad OpAmp).
One this side is another string of resistors (R27A, R27B, R27C: 3x300kohm), but strange enough they are connected directly to the input terminal without any protection. The NCV voltage led (LED3) and the transistor to drive it (Q2) is also placed here.
There is also space for unused protection (Q6 & Q8). The backlight led is a side emitting led (LED2) mounted at the border of the LCD display.
The pink zebra stripe that connects the display to the circuit board can be seen here.
Some backlight on the circuit board makes it easier to see the traces.
Conclusion
This meter is nice for measuring 100’s of mA or more without any voltage drop, using it for lower DC currents requires careful use of the zero button.
It has basic DMM functions, but it missing frequency and low currents.
It looks like it has real input protection and the CAT rating may be correct.
Notes
How do I review a DMM
