E-Stream ES18650-26EP 2600mAh (Pink) 2021
Official specifications:
Nominal voltage: 3.65V
Energy: 9.49 Wh
Discharge cut-off voltage: 2.75V
Maximum charge voltage: 4.2V
Internal Impedance ACIR: 25mOhm
Standard charge current: 1.3 (0.5C)
Standard charge cut-off current: 130mA (0.05C)
Maximum continuous charge current: 2.6A (1C)
Maximum pulse charge (< 2s) current: 5.2A (2C)
Standard discharge current: 2.6A (1C)
Maximum continuous discharge current: 15A (5.7C)
Maximum pulse (< 1s) discharge current: 20A (7.7C)
Cut-off temperature limit discharge: 60°C
Cycle life (80% of initial capacity): 1000 cycles (standard charge/discharge)
This is a 18650 cell with moderate capacity and moderate current capabilities.
%202021/DSC_4627.jpg)
%202021/DSC_4629.jpg)
%202021/DSC_4630.jpg)
%202021/DSC_4631.jpg)
%202021/DSC_4632.jpg)
%202021/E-Stream%20ES18650-26EP%202600mAh%20(Pink)%202021-Capacity.png)
The two cells tracks nicely and can easily deliver the rated 15A. My 30A test looks a bit strange and one of the cells got damaged during it.
%202021/E-Stream%20ES18650-26EP%202600mAh%20(Pink)%202021-Temp-15.0.png)
%202021/E-Stream%20ES18650-26EP%202600mAh%20(Pink)%202021-Temp-20.0.png)
%202021/E-Stream%20ES18650-26EP%202600mAh%20(Pink)%202021-Temp-30.0.png)
%202021/E-Stream%20ES18650-26EP%202600mAh%20(Pink)%202021-CapacityTimeHours.png)
%202021/E-Stream%20ES18650-26EP%202600mAh%20(Pink)%202021-CapacityTime.png)
%202021/E-Stream%20ES18650-26EP%202600mAh%20(Pink)%202021-Energy.png)
%202021/E-Stream%20ES18650-26EP%202600mAh%20(Pink)%202021-PowerLoadTime.png)
%202021/E-Stream%20ES18650-26EP%202600mAh%20(Pink)%202021-TripCurrent.png)
%202021/E-Stream%20ES18650-26EP%202600mAh%20(Pink)%202021-Charge.png)
Conclusion
The cells looks fine, they are not high capacity or high current, but they have a rather high cycle count (can handle many charges/discharges).
Notes and links
The batteries was supplied by E-Stream for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
