Ebat 20700 3000mAh E7-20P30 (Blue)
/DSC_0342.jpg)
Official specifications:
Model: E7-20P30
Normal voltage: 3.7V
Normal capacity: 3000mah
Charging voltage: 4.2V ± 0.5V
Discharging cut-off voltage: 2.5V
Discharge rate: 40A
Rechargeable: Yes
Size: 18±2mm Dia 70±1mm Length
Cycle life: > 500 times
Operation Temperature Range: Charge(0~45°C ) Discharge(–10~60°C )
/Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-info.png)
Ebat also have a battery in the new size 217100, capacity is not that high, but it can deliver lot of current.
/DSC_0341.jpg)
/DSC_0344.jpg)
/DSC_0345.jpg)
/DSC_0346.jpg)
/DSC_0347.jpg)
/Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-Capacity.png)
The discharge curves looks good with nice matching between the two cells and nearly constant capacity at any current.
/Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-Temp-15.0.png)
/Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-Temp-20.0.png)
/Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-Temp-30.0.png)
At 30A the battery gets warm, but not too warm, i.e. it can handle the current.
/Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-CapacityTimeHours.png)
/Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-CapacityTime.png)
/Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-Energy.png)
/Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-PowerLoadTime.png)
/Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-TripCurrent.png)
/Ebat%2020700%203000mAh%20E7-20P30%20(Blue)-Charge.png)
Conclusion
This is a nice high current battery and the slightly large size compare to a 18650 can be seen on the improved performance.
This battery is mostly for people that needs well above 10A, for lower currents look at a 18650.
Notes and links
The batteries was supplied by EBat for review.
Compare to 18650 and other batteries
Compare to 26650 and other batteries
