Test/Review of Efest 14500 800mAh (Black) 2014
Official specifications:
  • Weight: 55g
  • Length: 49.11mm
  • Diamter: 14.15mm
  • Top: Button top
  • Bottom: protected
  • Typical Capacity: 800mAh
  • Min capacity: 800mAh
  • Max discharge current: 3A
  • Max charge current: 3A
  • Recommended Max Discharge: 1.68A (2C)
  • Cycle life: 300 times
  • Normal Voltage: 3.7V
  • Full Charge voltage: 4.2V
  • Dishcarge temperature range:-10°C—60°C
  • Charge temperature range: 0°C—40°C
  • Storage: 1 year:-20°C—25°C, 3 months:-20°C—45°C, 1 month:-20°C—60°C
This battery is a protected battery.
The performance is fairly good, but with a mismatch in capacity.
Conclusion
A acceptable battery, that can deliver up to about 2A.
Notes and links
Comparison to other LiIon batteries
thanks for the tests!!
great battery review as always.
Efest? no thanks.
Another great HKJ cell test and report. Thank you very much for all the time and effort you put into these.
