Efest IMR18350 700mAh (Purple) 2016
%202016/DSC_3273.jpg)
Official specifications:
Typical Capacity: 700 mAh
Nominal Voltage: 3.7V
Discharge End Voltage: 2.5V
Max Charging Current: 1.5A
Charging Voltage: 4.20+–0.05V
Max Pulse Discharging Current: 10.5A
Dimensions: 34.73mm (L) x 18.10 mm (D)
Weight: 28g
%202016/Efest%20IMR18350%20700mAh%20(Purple)%202016-info.png)
%202016/DSC_3272.jpg)
%202016/DSC_3275.jpg)
%202016/DSC_3276.jpg)
%202016/DSC_3277.jpg)
%202016/DSC_3278.jpg)
%202016/Efest%20IMR18350%20700mAh%20(Purple)%202016-Capacity.png)
The cells tracks good between them, but there is a small capacity difference.
%202016/Efest%20IMR18350%20700mAh%20(Purple)%202016-Temp-7.0.png)
%202016/Efest%20IMR18350%20700mAh%20(Purple)%202016-Temp-10.0.png)
The temperature is not bad, even at 10A.
%202016/Efest%20IMR18350%20700mAh%20(Purple)%202016-CapacityTimeHours.png)
%202016/Efest%20IMR18350%20700mAh%20(Purple)%202016-CapacityTime.png)
%202016/Efest%20IMR18350%20700mAh%20(Purple)%202016-Energy.png)
%202016/Efest%20IMR18350%20700mAh%20(Purple)%202016-PowerLoadTime.png)
%202016/Efest%20IMR18350%20700mAh%20(Purple)%202016-TripCurrent.png)
%202016/Efest%20IMR18350%20700mAh%20(Purple)%202016-Charge.png)
Conclusion
This cell has good high current capability, but do not get it if you want a lot of capacity.
It looks like a good cell.
Notes and links
The batteries was supplied by Efest for review.
Comparison to other LiIon batteries
