Efest IMR18650 2100mAh (Purple) 2017
%202017/DSC_0814.jpg)
Official specifications:
Rated capacity: 2100mAh
Nominal voltage: 3.7V
Voltage at end of discharging: 2.5V
Max. charging current: 4A
Standard charge: 2A
Discharging current 25A
Pulse discharging current: 38A
Charging temperature range: 0°C ~ 45°C
Discharging temperature range: –20°C ~ 75°C
Inner resistance: 20mOhm
Cell size: 18.50 (±0.20)mm x 65.20 (±0.2)mm
%202017/Efest%20IMR18650%202100mAh%20(Purple)%202017-info.png)
A high current cell with fairly low capacity.
%202017/DSC_0813.jpg)
%202017/DSC_0816.jpg)
%202017/DSC_0817.jpg)
%202017/DSC_0818.jpg)
%202017/DSC_0819.jpg)
%202017/Efest%20IMR18650%202100mAh%20(Purple)%202017-Capacity.png)
The discharge curves looks very good with tracking and about constant capacity up to 20A.
%202017/Efest%20IMR18650%202100mAh%20(Purple)%202017-Temp-15.0.png)
%202017/Efest%20IMR18650%202100mAh%20(Purple)%202017-Temp-20.0.png)
%202017/Efest%20IMR18650%202100mAh%20(Purple)%202017-Temp-30.0.png)
The cell gets hot at 30A, but not too hot.
I have a suspicion that I did not mount the temperature sensor for the B cell correctly.
%202017/Efest%20IMR18650%202100mAh%20(Purple)%202017-CapacityTimeHours.png)
%202017/Efest%20IMR18650%202100mAh%20(Purple)%202017-CapacityTime.png)
%202017/Efest%20IMR18650%202100mAh%20(Purple)%202017-Energy.png)
%202017/Efest%20IMR18650%202100mAh%20(Purple)%202017-PowerLoadTime.png)
%202017/Efest%20IMR18650%202100mAh%20(Purple)%202017-TripCurrent.png)
%202017/Efest%20IMR18650%202100mAh%20(Purple)%202017-Charge.png)
Conclusion
The test shows a good quality cell that can deliver lot of current, but the capacity is not very high by todays standard.
Notes and links
The batteries was supplied by Efest for review.
Compare to 18650 and other batteries
