Efest IMR18650 3100mAh (Purple) 2017
%202017/DSC_0307.jpg)
Official specifications:
Capacity: 3100mAh
Nominal voltage: 3.7V
Voltage at end of discharging: 2.5V
Max charging current: 4A
Standard charge: 2A
Discharge current: 10A
Pulse discharge current: 20A
Charging temperature range: 0° ~ 45°C
Discharging temperature range: –20°C ~ 75°C
Inner resistance: 20mOhm
Cell size: 18.50 (±0.2)mm x 65.20 (±0.2)mm
%202017/Efest%20IMR18650%203100mAh%20(Purple)%202017-info.png)
A 18650 with 3100mAh and fairly high current.
%202017/DSC_0306.jpg)
I like the plastic box Efest uses, it is made to protect the battery from impacts.
%202017/DSC_0309.jpg)
%202017/DSC_0310.jpg)
%202017/DSC_0311.jpg)
%202017/DSC_0312.jpg)
%202017/Efest%20IMR18650%203100mAh%20(Purple)%202017-Capacity.png)
The discharge curves tracks very fine.
%202017/Efest%20IMR18650%203100mAh%20(Purple)%202017-Temp-10.0.png)
I forgot to put the temperature sensor on one of the batteries.
%202017/Efest%20IMR18650%203100mAh%20(Purple)%202017-Temp-15.0.png)
That means it did run the full discharge curve and got fairly warm
%202017/Efest%20IMR18650%203100mAh%20(Purple)%202017-Temp-20.0.png)
Especially at 20A (It did not work anymore after this test). This also shows that it has proper safety, that disables the battery if it gets way too hot.
%202017/Efest%20IMR18650%203100mAh%20(Purple)%202017-CapacityTimeHours.png)
%202017/Efest%20IMR18650%203100mAh%20(Purple)%202017-CapacityTime.png)
%202017/Efest%20IMR18650%203100mAh%20(Purple)%202017-Energy.png)
%202017/Efest%20IMR18650%203100mAh%20(Purple)%202017-PowerLoadTime.png)
%202017/Efest%20IMR18650%203100mAh%20(Purple)%202017-TripCurrent.png)
%202017/Efest%20IMR18650%203100mAh%20(Purple)%202017-Charge.png)
Conclusion
This cell has good performance at moderate current, but it is not a super high current cell.
Notes and links
The batteries was supplied by Efest for review.
Compare to 18650 and other batteries
