Efest IMR26650 4200mAh (Purple) 2017
%202017/DSC_0261.jpg)
Official specifications:
Rated capacity: 4200mAh
Nominal voltage: 3.7V
Voltage at end of discharging: 2.5V
Max. charging current: 4A
Standard charge: 2A
Discharging current 35A
Pulse discharging current: 50A
Charging temperature range: 0°C ~ 45°C
Discharging temperature range: –20°C ~ 75°C
Inner resistance: 20mOhm
Cell size: 18.5 (±0.2)mm x 65.2 (±0.2)mm
%202017/Efest%20IMR26650%204200mAh%20(Purple)%202017-info.png)
This is a high current 26650 battery.
%202017/DSC_0260.jpg)
%202017/DSC_0263.jpg)
%202017/DSC_0264.jpg)
%202017/DSC_0265.jpg)
%202017/DSC_0266.jpg)
%202017/Efest%20IMR26650%204200mAh%20(Purple)%202017-Capacity.png)
It do fairly good up to 20A, at 30A the cell is struggling a to handle the current.
%202017/Efest%20IMR26650%204200mAh%20(Purple)%202017-Temp-20.0.png)
%202017/Efest%20IMR26650%204200mAh%20(Purple)%202017-Temp-30.0.png)
At 30A I had to terminate the discharge a bit premature due to high temperature (I only had sensor on the B cell).
%202017/Efest%20IMR26650%204200mAh%20(Purple)%202017-CapacityTimeHours.png)
%202017/Efest%20IMR26650%204200mAh%20(Purple)%202017-CapacityTime.png)
%202017/Efest%20IMR26650%204200mAh%20(Purple)%202017-Energy.png)
%202017/Efest%20IMR26650%204200mAh%20(Purple)%202017-PowerLoadTime.png)
%202017/Efest%20IMR26650%204200mAh%20(Purple)%202017-TripCurrent.png)
%202017/Efest%20IMR26650%204200mAh%20(Purple)%202017-Charge.png)
Conclusion
This is a fairly good high current cell, but the rating is on the optimistic side.
Notes and links
The batteries was supplied by Efest for review.
Compare to 18650 and other batteries
/Golisi%20IMR26650%204300mAh%20(Gold)-Capacity.png)
