Eizfan IMR20700 3100mAh (Black-yellow) 2018
Official specifications:
Rated Capacity: 3100mAh
Continuous Discharge Current: 30A
Max. Short Peak Discharge CC: 40A
Rated Voltage: 3.7V
Internal Resistance: <30mOhm
Cut-off Discharge Voltage: 2.5V
Charge Upper Limit Voltage: 4.20±0.05V
Charging Metod: CC/CV 4.20V
Charging Time(Std): 4.0hours
Standard Charging Current: 0.2C A
Charging Current: 0.5C A
Standard Discharging Current: 0.2C A
Fast Discharging Current: 0.5C A
Max Discharging Current: 2C A
Weight: about 60g
Version: Flat Top
Operational Temperature: Charge (0 ~ 50°C)
This is high current cells and due to that the capacity is fairly low for this size.
The discharge curves tracks nicely at any tested current, at 30A I terminated the discharge a bit early due to the temperature.
Conclusion
The battery works well above 10A, but may be too hot at 30A continuous discharge.
Notes and links
Batteries was supplied by Eizfan (Efan) for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
