Eizfan IMR21700 5000mAh (Black-purple) 2019
%202019/DSC_4686.jpg)
Official specifications:
Model: IMR 21700
Rated Capacity: 5000mAh
Nominal Voltage: 3.7V
Voltage at end of discharge: 2.9V
Standard charge current: 740mA
Max. Charge Current: 3700mA
Max. continuous discharge current: 10A
Max. pulse discharge current: 15A
Charging temperature range: 0C to 45C
Discharge temperature range: –10C / –60C
Inner resistance: 16mOhm
Cell size : 21.8mm x 70.6mm
Weight: 85g/pc
%202019/Eizfan%20IMR21700%205000mAh%20(Black-purple)%202019-info.png)
Very high capacity 21700 batteries, this also means that they are not high current.
%202019/DSC_4685.jpg)
%202019/DSC_4688.jpg)
%202019/DSC_4689.jpg)
%202019/DSC_4690.jpg)
%202019/DSC_4691.jpg)
%202019/Eizfan%20IMR21700%205000mAh%20(Black-purple)%202019-Capacity.png)
The cells matches perfectly and they can deliver the rated current, at any higher current they will get into heat problems.
%202019/Eizfan%20IMR21700%205000mAh%20(Black-purple)%202019-Temp-10.0.png)
%202019/Eizfan%20IMR21700%205000mAh%20(Black-purple)%202019-Temp-15.0.png)
%202019/Eizfan%20IMR21700%205000mAh%20(Black-purple)%202019-Temp-20.0.png)
%202019/Eizfan%20IMR21700%205000mAh%20(Black-purple)%202019-CapacityTimeHours.png)
%202019/Eizfan%20IMR21700%205000mAh%20(Black-purple)%202019-CapacityTime.png)
%202019/Eizfan%20IMR21700%205000mAh%20(Black-purple)%202019-Energy.png)
%202019/Eizfan%20IMR21700%205000mAh%20(Black-purple)%202019-PowerLoadTime.png)
%202019/Eizfan%20IMR21700%205000mAh%20(Black-purple)%202019-TripCurrent.png)
%202019/Eizfan%20IMR21700%205000mAh%20(Black-purple)%202019-Charge.png)
Conclusion
A very good high capacity cell.
Notes and links
The batteries was supplied by Eizfan (Efan) for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
