Enercig 18650 3450mAh (Purple)
Official specifications:
Rated capacity: 3300mAh at 20°C
Minimum capacity: 3350mAh at 25°C
Typical capacity: 3450mAh at 25°C
Nominal voltage: 3.6V
Discharging end voltage: 2.5V
Charge current (Std.): 1.675A
Charging voltate: 4.20V +/-0.03V
Continuous discharge current (Max.): 10A
Internal impedance: <38mOhm at 1kHz
Weight: <49.5g
Cycle life: 300 cycles to 70% (Measured at 0.5C charge and 1C discharge)
Operating temperature: Charge: 10 ~ 45°C, Discharge: –20 ~ 60°C
Storage temperature: Less than 1 month: –20 ~ 50°C, less than 3 months: –20 ~ 40°C, less than 1 year: –20 ~ 20°C
/Enercig%2018650%203450mAh%20(Purple)-info.png)
This is a high capacity cell.
/DSC_5338.jpg)
/DSC_5340.jpg)
/DSC_5341.jpg)
/DSC_5342.jpg)
/DSC_5343.jpg)
/DSC_5344.jpg)
/Enercig%2018650%203450mAh%20(Purple)-Capacity.png)
The discharge curves tracks perfectly. The battery can handle 10A, but gets too warm at 15A.
/Enercig%2018650%203450mAh%20(Purple)-Temp-7.0.png)
/Enercig%2018650%203450mAh%20(Purple)-Temp-10.0.png)
The cell will be warm when drawing high current.
/Enercig%2018650%203450mAh%20(Purple)-Temp-15.0.png)
At 15A it gets way to hot and I stop the test.
/Enercig%2018650%203450mAh%20(Purple)-CapacityTimeHours.png)
/Enercig%2018650%203450mAh%20(Purple)-CapacityTime.png)
/Enercig%2018650%203450mAh%20(Purple)-Energy.png)
/Enercig%2018650%203450mAh%20(Purple)-PowerLoadTime.png)
/Enercig%2018650%203450mAh%20(Purple)-TripCurrent.png)
/Enercig%2018650%203450mAh%20(Purple)-Charge.png)
Conclusion
A very good cell, that can handle some current (But it is not a high current cell).
Notes and links
The batteries was supplied by ENERDan for review.
Compare to 18650 and other batteries
