Enercig 26650 5200mAh EC-265HC (Blue)
Official specifications:
Type. Capacity: 5200 mAh
Weight: 94 g
Diameter: 26.5 mm
Height: 66.5 mm
Rated voltage: 3.6 volt
Max. Charge Voltage: 4.2 Volt
End Voltage: 3.0 Volt
Max. Charging current: 3.0A
Max. Discharge current: 3.5C 18 A with thermal fuse at 80°C
Max. Discharge current:15 A 3C without temperature protection 80°C
Protection (PCB): No
/Enercig%2026650%205200mAh%20EC-265HC%20(Blue)-info.png)
This is a high current 26650 from German
/DSC_1838.jpg)
/DSC_1840.jpg)
/DSC_1841.jpg)
/DSC_1842.jpg)
/DSC_1843.jpg)
/DSC_1844.jpg)
/Enercig%2026650%205200mAh%20EC-265HC%20(Blue)-Capacity.png)
The battery has fairly constant capacity with load and the 15A rating looks fine enough, but there is some difference between the two batteries.
/Enercig%2026650%205200mAh%20EC-265HC%20(Blue)-Temp-10.0.png)
/Enercig%2026650%205200mAh%20EC-265HC%20(Blue)-Temp-15.0.png)
At 15A the temperature is warm, but still reasonable.
/Enercig%2026650%205200mAh%20EC-265HC%20(Blue)-Temp-20.0.png)
/Enercig%2026650%205200mAh%20EC-265HC%20(Blue)-CapacityTimeHours.png)
/Enercig%2026650%205200mAh%20EC-265HC%20(Blue)-CapacityTime.png)
/Enercig%2026650%205200mAh%20EC-265HC%20(Blue)-Energy.png)
/Enercig%2026650%205200mAh%20EC-265HC%20(Blue)-PowerLoadTime.png)
/Enercig%2026650%205200mAh%20EC-265HC%20(Blue)-TripCurrent.png)
/Enercig%2026650%205200mAh%20EC-265HC%20(Blue)-Charge.png)
Conclusion
The cell has very good performance at high current for a 26650 and the capacity is also fairly good.
Notes and links
The batteries was supplied by ENERDan for review.
Compare to 18650 and other batteries
