Enercig EC-14500HP 650mA (Gray)
Official specifications:
Typical capacity: 670mAh
Minimum capacity: 650mAh
Nominal voltage: 3.7V
Standard charge: 130mA (0.2C)
Standard discharge: 130mA (0.2C)
End-of-charge voltage: 4.20v+/-0.05V
End-of-discharge voltage: 3.00V
Quick charge current: 650mA (1C)
Quick discharge current: 6500mA (10C)
Max. discharge current: 13000mA (20C)
Cycle life: 300 times at 0.5C to 80%
Initial impedance: max 30mOhm
Operating temperature: Charging: 0° ~ 45°C, discharging: –20°C ~ 60°C
Storage temperature: –5°C ~ 35°C
This is a high current AA sized LiIon cell.
The discharge curves tracks fairly good and the battery works fine up to 10A, but 15A is too high.
Conclusion
These batteries has very good performance at high current, this also means that the capacity is a bit lower than low current cells.
Notes and links
The batteries was supplied by ENERDan for review.
Comparison to other LiIon batteries
