Enercig TN14500HP 650mAh (Gray)
/DSC_8712.jpg)
Official specifications:
Typical capacity: 670mAh
Minimum capacity: 650mAh
Nominal voltage: 3.7V
Standard charge: CC/CV, 0.2CA, 4.2V
Standard discharge: CC, 0.2CA, 3.00V
End-of-charge voltage: 4.20V +/0.05V
End-of-charge current: 0.02CA
End-of-discharge-voltage: 3.00V
Quick charge current: 1C, 650mA
Quick discharge current: 20C, 13000mA
Cycle life: 300 cycles to 80% at 0.5C
Initial impedance: max 30mOhm
Weight: approx 19.5g
Operating temperature: Charging: 0° ~ 45°C, Discharging: –20°C ~ 60°C
Storage temperature: –5°C ~ 35°C
/Enercig%20TN14500HP%20650mAh%20(Gray)-info.png)
High current AA sized LiIon batteries.
/DSC_8710.jpg)
/DSC_8714.jpg)
/DSC_8715.jpg)
/DSC_8716.jpg)
/Enercig%20TN14500HP%20650mAh%20(Gray)-Capacity.png)
There is a small difference between the two cells and one of the cells has trouble with 10A, they both handle 7A
/Enercig%20TN14500HP%20650mAh%20(Gray)-Temp-7.0.png)
/Enercig%20TN14500HP%20650mAh%20(Gray)-CapacityTimeHours.png)
/Enercig%20TN14500HP%20650mAh%20(Gray)-CapacityTime.png)
/Enercig%20TN14500HP%20650mAh%20(Gray)-Energy.png)
/Enercig%20TN14500HP%20650mAh%20(Gray)-PowerLoadTime.png)
/Enercig%20TN14500HP%20650mAh%20(Gray)-TripCurrent.png)
/Enercig%20TN14500HP%20650mAh%20(Gray)-Charge.png)
Conclusion
The batteries are not perfect, but for high current 14500 they are in the top.
Notes and links
The batteries was supplied by ENERDan for review.
The wrapper was supposed to be blue, but due to a production mistake they got a gray wrapper.
Comparison to other LiIon batteries
