Enerpower 18650 3.2V 1100mAh (Blue)
/DSC_3560.jpg)
Official specifications:
Standard capacity: 1100mAh
Capacity range: 1050 ~ 1200mAh
Standard voltage: 3.2V
Internal resistance (1kHz): <=18mOhm
Maximum charge current: 5.5A
Discharge cut-off voltage: 2.5V
Fast discharge current: 11A
Maximum continuous discharge current: 33A
Pulse discharge current: 40A for 10seconds
Cycle characteristic: 500cycles (100% DOD), 1000cycles (80% DOD), 3000cycles (50% DOD)
Working temperature: Charge 0°C ~ 55°C, Discharge –20°C ~ 60°C
Storage temperature: 3 months: –20°C ~ 45°C
/Enerpower%2018650%203.2V%201100mAh%20(Blue)-info.png)
This is high current LiFePO4 batteries.
/DSC_3527.jpg)
/DSC_3562.jpg)
/DSC_3563.jpg)
/DSC_3564.jpg)
/Enerpower%2018650%203.2V%201100mAh%20(Blue)-Capacity.png)
The batteries tracks nicely. The voltage is lower than normal LiIon, but it is stable during most of the discharge.
/Enerpower%2018650%203.2V%201100mAh%20(Blue)-Temp-15.0.png)
/Enerpower%2018650%203.2V%201100mAh%20(Blue)-Temp-20.0.png)
/Enerpower%2018650%203.2V%201100mAh%20(Blue)-Temp-30.0.png)
/Enerpower%2018650%203.2V%201100mAh%20(Blue)-CapacityTimeHours.png)
/Enerpower%2018650%203.2V%201100mAh%20(Blue)-CapacityTime.png)
/Enerpower%2018650%203.2V%201100mAh%20(Blue)-Energy.png)
/Enerpower%2018650%203.2V%201100mAh%20(Blue)-PowerLoadTime.png)
/Enerpower%2018650%203.2V%201100mAh%20(Blue)-TripCurrent.png)
/Enerpower%2018650%203.2V%201100mAh%20(Blue)-Charge.png)
Conclusion
High current at fairly stable voltage, but not much capacity.
This is a good LiFePO4 high current cell.
Notes and links
Compare to 18650 and other batteries
