Enerpower+ 18650 3000mAh (Gray)
Official specifications:
Nominal voltage: 3.61V
Rated discharge capacity: 3000mA
Rated discharge capacity 10A: 2700mA
Charge Method: CC-CV to 4.2 volt +/-0.05V with 100mA cut-off
Standard charge current: 1.5A
Rapid charge current: 4A
Discharge end voltage: 2.5V
Max. continious discharge current: 15A (Cell rating, protection prevents it).
Button top
%20bt/Enerpower+%2018650%203000mAh%20(Gray)%20bt-info.png)
This is high current protected batteries.
%20bt/DSC_3692.jpg)
%20bt/DSC_3700.jpg)
%20bt/DSC_3701.jpg)
%20bt/DSC_3702.jpg)
%20bt/DSC_3703.jpg)
%20bt/DSC_3704.jpg)
%20bt/Enerpower+%2018650%203000mAh%20(Gray)%20bt-Capacity.png)
The discharge curves looks perfect and the over current protection kicks in at 10A.
As usual I stops at 2.8V, discharging to 2.5V would have given more capacity.
%20bt/Enerpower+%2018650%203000mAh%20(Gray)%20bt-Temp-5.0.png)
%20bt/Enerpower+%2018650%203000mAh%20(Gray)%20bt-Temp-7.0.png)
At 7A the battery gets warm, but nothing to worry about.
%20bt/Enerpower+%2018650%203000mAh%20(Gray)%20bt-CapacityTimeHours.png)
%20bt/Enerpower+%2018650%203000mAh%20(Gray)%20bt-CapacityTime.png)
%20bt/Enerpower+%2018650%203000mAh%20(Gray)%20bt-Energy.png)
%20bt/Enerpower+%2018650%203000mAh%20(Gray)%20bt-PowerLoadTime.png)
%20bt/Enerpower+%2018650%203000mAh%20(Gray)%20bt-TripCurrent.png)
%20bt/Enerpower+%2018650%203000mAh%20(Gray)%20bt-Charge.png)
Flat top
%20ft/DSC_3693.jpg)
%20ft/Enerpower+%2018650%203000mAh%20(Gray)%20ft-info.png)
Same cell as above, still with protection, but this time with a flat top. Due to the small size of the top it might not work in all equipment expecting a flat top.
%20ft/DSC_3694.jpg)
%20ft/DSC_3695.jpg)
%20ft/DSC_3696.jpg)
%20ft/DSC_3697.jpg)
%20ft/DSC_3698.jpg)
%20ft/Enerpower+%2018650%203000mAh%20(Gray)%20ft-Capacity.png)
These curves also look perfect.
%20ft/Enerpower+%2018650%203000mAh%20(Gray)%20ft-Temp-5.0.png)
%20ft/Enerpower+%2018650%203000mAh%20(Gray)%20ft-Temp-7.0.png)
Temperature is the same.
%20ft/Enerpower+%2018650%203000mAh%20(Gray)%20ft-CapacityTimeHours.png)
%20ft/Enerpower+%2018650%203000mAh%20(Gray)%20ft-CapacityTime.png)
%20ft/Enerpower+%2018650%203000mAh%20(Gray)%20ft-Energy.png)
%20ft/Enerpower+%2018650%203000mAh%20(Gray)%20ft-PowerLoadTime.png)
%20ft/Enerpower+%2018650%203000mAh%20(Gray)%20ft-TripCurrent.png)
%20ft/Enerpower+%2018650%203000mAh%20(Gray)%20ft-Charge.png)
Conclusion
Nost high current cells do not have protection, this cell here is an exception, it limits the maximum current to a lower level than the cell really can deliver and the voltage is slightly lower, but makes it a very safe cell to use when currents up to 5-9A is required.
This is a very good cell when protection and current is required. I did not see any performance difference between button and flat top.
Notes and links
The batteries was supplied by Enerpower for review.
Compare to 18650 and other batteries
