Enerpower 26650 3.2V 3000mAh (Blue)
Official specifications:
Chemistry: LiFePo4
Format: 26650
Brand: ENERpower
Manufacturer: Heter
UL: MH48108
Nominal voltage: 3.2V
Discharge Voltage: 2.5V
End-of-Charge Voltage: 3.6V
Maximum charging current: 9A
Capacity: 3000 mAh
Continuous load (in amperes): 10C (approx. 30A)
Internal resistance:<15m?
Pulse Load: 45A / 5 Seconds
Weight: 85 g.
Dimensions: 26.15 mm diameter / 65.60 mm length
Protective circuit: NONE
Lifetime: 2000 full cycles (100% DOD) / 4000 full cycles (80% DoD) / 6000 full cycles (60% DOD)
LiFePO4 cells in 26650 format, they can deliver a fairly high current.
/DSC_4580.jpg)
/DSC_4581.jpg)
/DSC_4582.jpg)
/DSC_4583.jpg)
/Enerpower%2026650%203.2V%203000mAh%20(Blue)-Capacity.png)
The two cells has fairly well matching discharge curves and they have flat output voltage because they are LiFePO4.
/Enerpower%2026650%203.2V%203000mAh%20(Blue)-Temp-15.0.png)
/Enerpower%2026650%203.2V%203000mAh%20(Blue)-Temp-20.0.png)
/Enerpower%2026650%203.2V%203000mAh%20(Blue)-Temp-30.0.png)
/Enerpower%2026650%203.2V%203000mAh%20(Blue)-CapacityTimeHours.png)
/Enerpower%2026650%203.2V%203000mAh%20(Blue)-CapacityTime.png)
/Enerpower%2026650%203.2V%203000mAh%20(Blue)-Energy.png)
/Enerpower%2026650%203.2V%203000mAh%20(Blue)-PowerLoadTime.png)
/Enerpower%2026650%203.2V%203000mAh%20(Blue)-TripCurrent.png)
/Enerpower%2026650%203.2V%203000mAh%20(Blue)-Charge.png)
Conclusion
These batteries do not have high capacity, but they can deliver a lot of current and output voltage is stable around 3V.
Notes and links
The batteries was supplied by batteridoktorn.se for review.
Compare to 18650 and other batteries
