EU PLUG Wall Charger Dual USB ZYBB-1516
Official specifications:
input voltage range: 100-240V
input voltage frequency: 50-60Hz
output voltage: 5V
the output current: 2300mA (Charger list 2.1A)
output interface: Standard USB interface
there is an indicator light
I got it from ebay dealer: bigmall2016
It arrived in a plastic bag in a plastic envelope.
Measurements
Power consumption when idle is 0.11 Watt
USB output #1 is coded as DCP, Samsung
USB output #2 is coded as Apple 1A
The two USB outputs are in parallel.
Weight: 32.5g
Size: 73.2 x 39.8 x 25.0mm
The charger can deliver 2.5A before the output voltage start dropping.
The other output is the same
And also when used together.
At 120VAC the output current is only 1.8A
For a load test I used 5V 2.1A load for one hour, it worked fine.
M1: 80.3°C, HS1: 84.4°C
But the charge got rather hot. HS1 is the transformer.
HS1: 80.4°C
HS1 is the rectifier diode.
M1: 74.9°C, HS1: 76.7°C
M1: 66.2°C, HS1: 66.6°C
HS1: 92.7°C
At 0.5A the noise is 121mV rms and 1559mVpp.
At 1A the noise is 158mV rms and 1789mVpp.
At 2A the noise is 227mV rms and 2900mVpp, output noise is very bad.
Tear down
Mounting the top in my vice and giving the bottom a whack with my mallet was enough to open it, a spudger would also have done it.
On this side is the fusible input resistor, the bridge rectifier, the switcher, a fake safety capacitor, the opto feedback and a big diode.
This side is mostly resistors and capacitors, but there is also a diode and the reference (431).
The distance between mains and low volt side is supposed to be above 6mm, here it is around 1mm near the opto coupler.
The charger passed the 2830 volt test, but failed the 4242 volt test between mains and low volt side, this makes it unsafe for 230VAC countries.
Conclusion
With a fake safety capacitor and low creepage distance the charger has bad safety, it do also have a lot of noise on the output.
Stay away from this charger.
Notes
The charger was supplied by a reader for review.
How does a usb charger work?
