GIF TR16340 2500mAh (Yellow)
Official specifications:
Model: 16340
Capacity: 2500mAh
Voltage: 3.7V
Chemistry: Li-ion
Color: Yellow, Red
Size: 32mm(Length) x 16mm(Dia.)
/GIF%20TR16340%202500mAh%20(Yellow)-info.png)
A small battery rated at the same capacity as much larger batteries, this can only be a fake rating.
/DSC_8545.jpg)
/DSC_8547.jpg)
/DSC_8548.jpg)
/DSC_8549.jpg)
/DSC_8550.jpg)
/GIF%20TR16340%202500mAh%20(Yellow)-Capacity.png)
The battery can deliver 300mAh as long as the load is below 1A, this is not very impressive. AT low load they are surprising well matched, probably because they are manufactured with this capacity.
/GIF%20TR16340%202500mAh%20(Yellow)-Temp-1.0.png)
And it do not has enough energy to get really warm.
/GIF%20TR16340%202500mAh%20(Yellow)-CapacityTimeHours.png)
/GIF%20TR16340%202500mAh%20(Yellow)-CapacityTime.png)
/GIF%20TR16340%202500mAh%20(Yellow)-Energy.png)
/GIF%20TR16340%202500mAh%20(Yellow)-PowerLoadTime.png)
/GIF%20TR16340%202500mAh%20(Yellow)-TripCurrent.png)
/GIF%20TR16340%202500mAh%20(Yellow)-Charge.png)
Conclusion
These cells may be cheap, but compare to what you get they are way to expensive. Any decent cell will have about double capacity and handle higher load much better.
I will rate them as bad
Notes and links
Comparison to other LiIon batteries
