Golisi IMR18650 3000mAh G30 (Gold)
Official specifications:
Nominal capacity: 3000mAh
Constant current: 25A
Nominal voltage: 3.7V
Discharge cut-off voltage: 2.75V
Charging cut-off voltage: 2.20 +/- 0.05V
Internal impedance: 30mOhm
Standard charging current: cc/cv <=2A
Size: Diameter: 18mm, Height: 65mm
Net weight: 46g
Cycle times: >800
Operating temperature: Charging: 0°C ~ 45°C, discharging: –20°C ~ 60°C
Storage temperature: Room temperature or below.
/Golisi%20IMR18650%203000mAh%20G30%20(Gold)-info.png)
This is a high current 18650 with fairly high capacity.
/DSC_2133.jpg)
/DSC_2134.jpg)
/DSC_2136.jpg)
/DSC_2137.jpg)
/DSC_2139.jpg)
/DSC_2140.jpg)
/Golisi%20IMR18650%203000mAh%20G30%20(Gold)-Capacity.png)
The battery handles up to 15A nicely, the two cells tracks very fine.
/Golisi%20IMR18650%203000mAh%20G30%20(Gold)-Temp-15.0.png)
At 15A the cell gets fairly hot
/Golisi%20IMR18650%203000mAh%20G30%20(Gold)-Temp-20.0.png)
At 20A I had to stop the discharge due to temperature.
/Golisi%20IMR18650%203000mAh%20G30%20(Gold)-Temp-30.0.png)
And also at 30A.
/Golisi%20IMR18650%203000mAh%20G30%20(Gold)-CapacityTimeHours.png)
/Golisi%20IMR18650%203000mAh%20G30%20(Gold)-CapacityTime.png)
/Golisi%20IMR18650%203000mAh%20G30%20(Gold)-Energy.png)
/Golisi%20IMR18650%203000mAh%20G30%20(Gold)-PowerLoadTime.png)
/Golisi%20IMR18650%203000mAh%20G30%20(Gold)-TripCurrent.png)
/Golisi%20IMR18650%203000mAh%20G30%20(Gold)-Charge.png)
Conclusion
The cell can handle a good amount of current and has good capacity, but rating the cell for 25A continuous discharge is a optimistic.
I will call it a good high cell.
Notes and links
The batteries was supplied by Golisi for review.
Compare to 18650 and other batteries
