Gpower 18650 3000mAh (Yellow-black)
Official specifications:
Capacity: 3000mAh
MAX Discharge Current: 40A
CDR (Continuous Discharge Current): 20A
Voltage: 3.7v
Material: Li-ion
Length: 65.30mm
Diameter: 18.20mm
Top: Flat top(18mm 65mm)
Warranty: 12 months
/Gpower%2018650%203000mAh%20(Yellow-black)-info.png)
A high capacity high current rated cell.
/DSC_6931.jpg)
/DSC_6933.jpg)
/DSC_6934.jpg)
/DSC_6935.jpg)
/DSC_6936.jpg)
/DSC_6937.jpg)
/Gpower%2018650%203000mAh%20(Yellow-black)-Capacity.png)
This chart is a mess, the two cells has different capacity. At 0.2A A was 2435mAh and B was 2749mAh, neither reach the specified 3000mAh
/Gpower%2018650%203000mAh%20(Yellow-black)-Temp-15.0.png)
Both cells can handle 15A without getting too hot.
/Gpower%2018650%203000mAh%20(Yellow-black)-Temp-20.0.png)
At 20A the B cell gets too hot and I terminate the test.
/Gpower%2018650%203000mAh%20(Yellow-black)-Temp-30.0.png)
The B cell cannot handle 30A, the A cell gets too hot after some time.
/Gpower%2018650%203000mAh%20(Yellow-black)-CapacityTimeHours.png)
/Gpower%2018650%203000mAh%20(Yellow-black)-CapacityTime.png)
/Gpower%2018650%203000mAh%20(Yellow-black)-Energy.png)
/Gpower%2018650%203000mAh%20(Yellow-black)-PowerLoadTime.png)
/Gpower%2018650%203000mAh%20(Yellow-black)-TripCurrent.png)
/Gpower%2018650%203000mAh%20(Yellow-black)-Charge.png)
Conclusion
I do not like these cells, both are below specifications and they are very different.
As 3000mAh high current cells they are bad.
Notes and links
The batteries was supplied by gpower-battery.com for a review.
Compare to 18650 and other batteries
