GTL 26650 12000mAh (White)
Official specifications:
Model: 26650
Type: Rechargeable Li-lithium battery
Capacity: 12000mAh
Voltage: 3.7V
Max Continuous Discharge: 8A
Max Peak Discharge: 4A Peak lower than continuous?
Size: about 66*25*25mm
Colour: White
/GTL%2026650%2012000mAh%20(White)-info.png)
Super high capacity 26650, again a battery with wrong specifications.
/DSC_8589.jpg)
/DSC_8591.jpg)
/DSC_8592.jpg)
/DSC_8593.jpg)
/DSC_8594.jpg)
/GTL%2026650%2012000mAh%20(White)-Capacity.png)
There is significant difference between the two batteries and the capacity is 2000 and 2200mAh at low current. The batteries can handle up to about 7A.
/GTL%2026650%2012000mAh%20(White)-Temp-7.0.png)
At 7A the A cell get warmest.
/GTL%2026650%2012000mAh%20(White)-Temp-10.0.png)
At 10A it is the B cell.
/GTL%2026650%2012000mAh%20(White)-CapacityTimeHours.png)
/GTL%2026650%2012000mAh%20(White)-CapacityTime.png)
/GTL%2026650%2012000mAh%20(White)-Energy.png)
/GTL%2026650%2012000mAh%20(White)-PowerLoadTime.png)
/GTL%2026650%2012000mAh%20(White)-TripCurrent.png)
/GTL%2026650%2012000mAh%20(White)-Charge.png)
Conclusion
These cells where never going to be anywhere near the rated capacity, instead they have less capacity than most other 26650 cells.
I will call them bad cells.
Notes and links
Compare to 18650 and other batteries
