GTL LS14500 2300mAh (Purple)
Official specifications:
Capacity: 2300mAh
Voltage: 3.7V
Color: Purple
Size: 14 x 50mm
/GTL%20LS14500%202300mAh%20(Purple)-info.png)
GTL a brand with very high capacity specifications on their batteries, the problem is actual performance.
/DSC_6748.jpg)
/DSC_6750.jpg)
/DSC_6751.jpg)
/DSC_6752.jpg)
/DSC_6753.jpg)
/DSC_6754.jpg)
/GTL%20LS14500%202300mAh%20(Purple)-Capacity.png)
Up to 1A these cells can deliver 300mAh with not too bad matching between the cells
I dropped the temp curves, these cells stay fairly cool.
/GTL%20LS14500%202300mAh%20(Purple)-CapacityTimeHours.png)
/GTL%20LS14500%202300mAh%20(Purple)-CapacityTime.png)
/GTL%20LS14500%202300mAh%20(Purple)-Energy.png)
/GTL%20LS14500%202300mAh%20(Purple)-PowerLoadTime.png)
/GTL%20LS14500%202300mAh%20(Purple)-TripCurrent.png)
/GTL%20LS14500%202300mAh%20(Purple)-Charge.png)
Conclusion
The capacity is about half compared to good 14500 cells and good cells can deliver 3A, not only 1A.
They are useable, but with the low capacity and current ability I will rate them bad (I wonder if they are produced as cheap cells).
Notes and links
Comparison to other LiIon batteries
