HDS Systems INR16340 700mAh (Red)
Official specifications:
Nominal voltage: 3.6V
Charge voltage: 4.2V
Capacity: 700mAh
Maximum discharge current: 2.1A
Chemistry: INR (Lithium Nickel Manganese Cobalt Oxide)
/HDS%20Systems%20INR16340%20700mAh%20(Red)-info.png)
This battery is sold by one of the premium flashlight makers in US doe their flashlight.
/HDS%20Systems%20INR16340%20700mAh%20(Red)-Capacity.png)
The batteries are not perfectly matches, this is fairly common for this size. The batteries can deliver up to about 2A
/HDS%20Systems%20INR16340%20700mAh%20(Red)-CapacityTimeHours.png)
/HDS%20Systems%20INR16340%20700mAh%20(Red)-CapacityTime.png)
/HDS%20Systems%20INR16340%20700mAh%20(Red)-Energy.png)
/HDS%20Systems%20INR16340%20700mAh%20(Red)-PowerLoadTime.png)
/HDS%20Systems%20INR16340%20700mAh%20(Red)-TripCurrent.png)
/HDS%20Systems%20INR16340%20700mAh%20(Red)-Charge.png)
Internal resistance calculated by turning 0.5A on/off during a discharge.
Conclusion
This is a good quality 16340 for flashlight use.
Notes and links
The batteries was supplied by hdssystems.com for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
