Hohm 21700 Run 3023mAh (Black-white)
/DSC_2758.jpg)
Official specifications:
Capacity: 3023mAh
Max Charge Rate: 5.29A
Continuous Discharge Rate: 39.1A
Max @ 80oC | 3.2V cut-off: 49.5A
Pulse | Peak: 56.4A (<=5 SEC ON >=30 SEC OFF)
Cycle Life Retention: 500 Cycles (73), 1000 (64)
Chemistry Type: QSP Li-NMC
/Hohm%2021700%20Run%203023mAh%20(Black-white)-info.png)
This is a low capacity and very high current 21700 cell.
/DSC_2752.jpg)
/DSC_2753.jpg)
/DSC_2754.jpg)
/DSC_2755.jpg)
/DSC_2757.jpg)
/DSC_2760.jpg)
/DSC_2761.jpg)
/DSC_2762.jpg)
/DSC_2763.jpg)
/Hohm%2021700%20Run%203023mAh%20(Black-white)-Capacity.png)
The two cell do nearly match and can deliver at least 30A with a minor capacity loss.
/Hohm%2021700%20Run%203023mAh%20(Black-white)-Temp-15.0.png)
/Hohm%2021700%20Run%203023mAh%20(Black-white)-Temp-20.0.png)
/Hohm%2021700%20Run%203023mAh%20(Black-white)-Temp-30.0.png)
/Hohm%2021700%20Run%203023mAh%20(Black-white)-CapacityTimeHours.png)
/Hohm%2021700%20Run%203023mAh%20(Black-white)-CapacityTime.png)
/Hohm%2021700%20Run%203023mAh%20(Black-white)-Energy.png)
/Hohm%2021700%20Run%203023mAh%20(Black-white)-PowerLoadTime.png)
/Hohm%2021700%20Run%203023mAh%20(Black-white)-TripCurrent.png)
/Hohm%2021700%20Run%203023mAh%20(Black-white)-Charge.png)
Conclusion
The batteries can deliver a lot of current, but capacity is in the low end for 21700 cells. I.e. these cells are mostly interesting if there is a need for very high current.
Notes and links
The batteries was supplied by Hohmtech for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
