Imren IMR18650 3000mAh (Yellow)
/DSC_1998.jpg)
Official specifications:
Weight: 50g
Capacity: 3000mAh
Length : 65.05mm
Diameter: 18.51mm
Voltage: 3.7V
Excellent high-current discharge performance
Model: 18650
Material: Li-Mn
/Imren%20IMR18650%203000mAh%20(Yellow)-info.png)
Imren has two different 3000mAh cells, both high current.
/DSC_1997.jpg)
/DSC_2000.jpg)
/DSC_2001.jpg)
/DSC_2002.jpg)
/DSC_2003.jpg)
/Imren%20IMR18650%203000mAh%20(Yellow)-Capacity.png)
The discharge curves looks good, nearly constant capacity and very good tracking between the cells.
I had to stop early on the high current discharges to avoid melting my test station.
/Imren%20IMR18650%203000mAh%20(Yellow)-Temp-15.0.png)
/Imren%20IMR18650%203000mAh%20(Yellow)-Temp-20.0.png)
/Imren%20IMR18650%203000mAh%20(Yellow)-Temp-30.0.png)
At 30A the temperature increases very fast, I terminated the discharge after 2 minutes and 30 seconds.
/Imren%20IMR18650%203000mAh%20(Yellow)-CapacityTimeHours.png)
/Imren%20IMR18650%203000mAh%20(Yellow)-CapacityTime.png)
/Imren%20IMR18650%203000mAh%20(Yellow)-Energy.png)
/Imren%20IMR18650%203000mAh%20(Yellow)-PowerLoadTime.png)
/Imren%20IMR18650%203000mAh%20(Yellow)-TripCurrent.png)
/Imren%20IMR18650%203000mAh%20(Yellow)-Charge.png)
Conclusion
The cells looks good, but they cannot deliver 30A continious.
Notes and links
The battery was supplied by Imren for a review.
This test is run on my updated equipment and is not directly comparable to the other Imren 3000mAh test.
Compare to 18650 and other batteries
