Jaxman 26650A 5000mAh (Green)
/DSC_9068.jpg)
Official specifications:
Voltage : 3.7V. Max.4.2V, Do not Discharge less than 2.75V
Size: OD26mm x L 65.0mm
Weight : about95g/pcs
Fully Discharge voltage: from 4.2V to 2.75
THIS BATTERY IS NOT A PANASONIC PRODUCT! WE HAVE A SUPPLIER WHO PRODUCES BATTERY, WE DESIGNED THE SKIN (heat shrink tube) AND TITLED IT 26650A .ALL IS BY OURSELVES.
THE CAPACITY OF THE BATTERY IS REAL >5000mAH, normally is 5000-5300mAH varies from different batches.
/Jaxman%2026650A%205000mAh%20(Green)-info.png)
Another 26650 battery with high capacity.
/DSC_9067.jpg)
/DSC_9070.jpg)
/DSC_9071.jpg)
/DSC_9073.jpg)
/Jaxman%2026650A%205000mAh%20(Green)-Capacity.png)
The two cell has different capacity, i.e. they are not very good for usage in series. They can deliver about 7A
/Jaxman%2026650A%205000mAh%20(Green)-Temp-7.0.png)
/Jaxman%2026650A%205000mAh%20(Green)-Temp-10.0.png)
/Jaxman%2026650A%205000mAh%20(Green)-Temp-15.0.png)
/Jaxman%2026650A%205000mAh%20(Green)-CapacityTime.png)
/Jaxman%2026650A%205000mAh%20(Green)-Energy.png)
/Jaxman%2026650A%205000mAh%20(Green)-PowerLoadTime.png)
/Jaxman%2026650A%205000mAh%20(Green)-TripCurrent.png)
/Jaxman%2026650A%205000mAh%20(Green)-Charge.png)
Conclusion
This is a fairly average high capacity 26650, this cell can deliver some current, but is not a high current cell.
Notes and links
Compare to 18650 and other batteries
