K2 Energy 14500 LiFePO4 500mAh (White)
/DSC_3817.jpg)
Official specifications:
Nominal voltage: 3.2V
Nominal capacity: 500mAh
Nominal energy: 1.6Wh
Chemistry: Lithium Iron Phosphate
/K2%20Energy%2014500%20LiFePO4%20500mAh%20(White)-info.png)
This is a LiFePO4 cell, this means lower charge voltage, less energy content and longer cell life.
/DSC_3804.jpg)
/DSC_3819.jpg)
/DSC_3820.jpg)
/DSC_3821.jpg)
/K2%20Energy%2014500%20LiFePO4%20500mAh%20(White)-Capacity.png)
This type of chemistry has a very flat discharge curve and the two cells match nicely.
/K2%20Energy%2014500%20LiFePO4%20500mAh%20(White)-Temp-7.0.png)
/K2%20Energy%2014500%20LiFePO4%20500mAh%20(White)-Temp-10.0.png)
The temperature raise is not very high, even at 10A.
/K2%20Energy%2014500%20LiFePO4%20500mAh%20(White)-Temp-15.0.png)
At 15A there is no time for temperature raise, before my equipment cuts the discharge due to low voltage.
/K2%20Energy%2014500%20LiFePO4%20500mAh%20(White)-CapacityTimeHours.png)
/K2%20Energy%2014500%20LiFePO4%20500mAh%20(White)-CapacityTime.png)
/K2%20Energy%2014500%20LiFePO4%20500mAh%20(White)-Energy.png)
/K2%20Energy%2014500%20LiFePO4%20500mAh%20(White)-PowerLoadTime.png)
/K2%20Energy%2014500%20LiFePO4%20500mAh%20(White)-TripCurrent.png)
/K2%20Energy%2014500%20LiFePO4%20500mAh%20(White)-Charge.png)
Conclusion
Depending on equipment the lower voltage may be an advantage or disadvantage, the capacity and energy is lower than normal LiIon. This chemistry is safer, because the self-ignition temperature is much higher.
For some applications this will be a good cell.
Notes and links
Comparison to other LiIon batteries
