Keeppower 14430 950mAh P1443C2 (Black) 2020
%202020/DSC_4067.jpg)
Official specifications:
Voltage: 3.70V
Rated capacity: 850mAh
Minimum Capacity: 800mAh
Discharge cut-off voltage: 2.50V
Charge voltage: 4.20V +/- 0.05V
Standard charge current: 500mA
Maximum constant discharge current: 2A
%202020/Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-info.png)
Protected LiIon 14430 batteries from Keeppower, these batteries are about 5mm shorter than AA batteries, but with the same diameter and the higher LiIon voltage.
%202020/DSC_4066.jpg)
%202020/DSC_4069.jpg)
%202020/DSC_4070.jpg)
%202020/DSC_4071.jpg)
%202020/Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-Capacity.png)
The two batteries tracks nicely, they are rated for 2A and can handle it.
%202020/Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-Temp-1.0.png)
%202020/Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-Temp-2.0.png)
%202020/Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-Temp-3.0.png)
%202020/Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-CapacityTimeHours.png)
%202020/Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-CapacityTime.png)
%202020/Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-Energy.png)
%202020/Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-PowerLoadTime.png)
%202020/Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-TripCurrent.png)
%202020/Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-Charge.png)
Conclusion
This looks like good batteries, but they are not for high current and there size is a bit uncommon.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
