Keeppower 18650 2600mAh P1826R (Black) 2017
%202017/DSC_2621.jpg)
Official specifications:
Part No.: P1826R
Protected 18650 Li-ion Rechargeable Battery
Minimum Capacity: 2500mAh
Typical Capacity: 2600mAh
Normal Voltage: 3.7V
Maximum Continuous Charging Current: 5A
Maximum Continuous Discharging Current: 15A
In Built Safety Circuitry
Protection Circuit (Against over charge, over discharge, over current and short-circuit.)
4.20V maximum voltage and 2.50V cut-off voltage
Over 500 charge-discharge cycles
%202017/Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-info.png)
This is high current protected batteries with moderate capacity.
%202017/DSC_2620.jpg)
%202017/DSC_2623.jpg)
%202017/DSC_2624.jpg)
%202017/DSC_2625.jpg)
%202017/Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-Capacity.png)
The discharge curves looks very good with perfect tracking.
%202017/Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-Temp-10.0.png)
%202017/Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-Temp-15.0.png)
%202017/Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-CapacityTimeHours.png)
%202017/Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-CapacityTime.png)
%202017/Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-Energy.png)
%202017/Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-PowerLoadTime.png)
%202017/Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-TripCurrent.png)
The protection trips above 15A, but below 20A, I could not do 20A discharge curves.
%202017/Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-Charge.png)
Conclusion
This is a good battery and with the protection there is no risk over over discharging the battery.
Notes and links
The battery was supplied by Keeppower for review.
Compare to 18650 and other batteries
