Keeppower 18650 3120mAh P1831R (Black) 2017
%202017/DSC_2629.jpg)
Official specifications:
Part No.: P1831R
Protected 18650 Li-ion Rechargeable Battery
Minimum Capacity: 3000mAh
Typical Capacity: 3120mAh
Normal Voltage: 3.7V
Maximum Continuous Charging Current: 5A
Maximum Continuous Discharging Current: 15A
In Built Safety Circuitry
Protection Circuit (Against over charge, over discharge, over current and short-circuit.)
4.20V maximum voltage and 2.50V cut-off voltage
Over 500 charge-discharge cycles
Max. Size: 18.8 x 69.0mm
Weight: 48g
Max. 15A Continuous Discharge Current
%202017/Keeppower%2018650%203120mAh%20P1831R%20(Black)%202017-info.png)
A protected battery that can deliver a lot of current and has good capacity.
%202017/DSC_2628.jpg)
%202017/DSC_2631.jpg)
%202017/DSC_2632.jpg)
%202017/DSC_2633.jpg)
%202017/Keeppower%2018650%203120mAh%20P1831R%20(Black)%202017-Capacity.png)
The discharge curves tracks very fine.
The B battery jumps a bit in voltage, it looks like a loose connection in my test setup.
%202017/Keeppower%2018650%203120mAh%20P1831R%20(Black)%202017-Temp-10.0.png)
A full discharge at 15A is a bit much for this battery, it gets rather hot. I had to stop one of the discharges.
%202017/Keeppower%2018650%203120mAh%20P1831R%20(Black)%202017-Temp-15.0.png)
At 15A I had to stop both discharges due to temperature.
%202017/Keeppower%2018650%203120mAh%20P1831R%20(Black)%202017-Temp-20.0.png)
%202017/Keeppower%2018650%203120mAh%20P1831R%20(Black)%202017-CapacityTimeHours.png)
%202017/Keeppower%2018650%203120mAh%20P1831R%20(Black)%202017-CapacityTime.png)
%202017/Keeppower%2018650%203120mAh%20P1831R%20(Black)%202017-Energy.png)
%202017/Keeppower%2018650%203120mAh%20P1831R%20(Black)%202017-PowerLoadTime.png)
%202017/Keeppower%2018650%203120mAh%20P1831R%20(Black)%202017-TripCurrent.png)
%202017/Keeppower%2018650%203120mAh%20P1831R%20(Black)%202017-Charge.png)
Conclusion
This is a good cell, but the build in protection do not trip on overload (It will probably trip on higher currents).
Notes and links
The battery was supplied by Keeppower for review.
Compare to 18650 and other batteries
