Keeppower 18650 3500mAh P1835U (White-blue) 2020
%202020/DSC_4140.jpg)
Official specifications:
Minimum Capacity: 3350mAh
Nominal Capacity: 3500mAh
Nominal Voltage: 3.7V
Discharge End Voltage: 2.5V
Standard Charging Current: 1.0A
Max. Continuous Discharging Current: 5A
Built in micro-usb charge port
%202020/Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-info.png)
A 3500mAh protected 18650 with build-in USB-charger.
%202020/DSC_4139.jpg)
%202020/DSC_4142.jpg)
%202020/DSC_4143.jpg)
%202020/DSC_4144.jpg)
%202020/DSC_4146.jpg)
%202020/DSC_4147.jpg)
A pack contains two batteries and a dual usb charge cable.
%202020/Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-Capacity.png)
The two cells tracks nicely and can handle more than 7A before getting too hot or protection will kick in.
%202020/Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-Temp-7.0.png)
%202020/Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-Temp-10.0.png)
%202020/Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-CapacityTimeHours.png)
%202020/Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-CapacityTime.png)
%202020/Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-Energy.png)
%202020/Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-PowerLoadTime.png)
%202020/Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-TripCurrent.png)
%202020/Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-Charge.png)
It looks like the USB charger reduces current probably due to temperature at the start of charging.
Conclusion
A good protected battery with good capacity, the USB charging can be useful on the go or if you only have a few 18650 batteries.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
