Keeppower 20700 4250mAh P2070J (Black) 2019
%202019/DSC_6841.jpg)
Official specifications:
Capacity min.: 4250mAh
Capacity typ.: 4050mAh
Nominal voltage: 3.70V
Charge voltage: 4.20+/-0.05V
Standard discharge cut-off voltage: 2.50V
Standard charge current: 2000mA
Charge termination current: 80mA
Max. continuous discharge current: 10A
%202019/Keeppower%2020700%204250mAh%20P2070J%20(Black)%202019-info.png)
This is a protected 20700 cell with fairly good capacity
%202019/DSC_6840.jpg)
%202019/DSC_6843.jpg)
%202019/DSC_6844.jpg)
%202019/DSC_6845.jpg)
%202019/Keeppower%2020700%204250mAh%20P2070J%20(Black)%202019-Capacity.png)
The two cells matches very fine and capacity drops slowly with higher current. The protection trips after some time at 10A.
%202019/Keeppower%2020700%204250mAh%20P2070J%20(Black)%202019-Temp-7.0.png)
%202019/Keeppower%2020700%204250mAh%20P2070J%20(Black)%202019-Temp-10.0.png)
%202019/Keeppower%2020700%204250mAh%20P2070J%20(Black)%202019-CapacityTimeHours.png)
%202019/Keeppower%2020700%204250mAh%20P2070J%20(Black)%202019-CapacityTime.png)
%202019/Keeppower%2020700%204250mAh%20P2070J%20(Black)%202019-Energy.png)
%202019/Keeppower%2020700%204250mAh%20P2070J%20(Black)%202019-PowerLoadTime.png)
%202019/Keeppower%2020700%204250mAh%20P2070J%20(Black)%202019-TripCurrent.png)
%202019/Keeppower%2020700%204250mAh%20P2070J%20(Black)%202019-Charge.png)
Conclusion
This is a good protected cell.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
