Keeppower 21700 5000mAh P5150TC (White-Blue) 2020
%202020/DSC_4322.jpg)
Official specifications:
Voltage: 3.60V
Typical capacity: 5000mAh
Minimum Capacity: 4900mAh
Discharge cut-off voltage: 2.50V
Charge voltage: 4.20V +/- 0.05V
Standard charge current: 1300mA
Maximum constant discharge current: 8A
USB type-C charge socket.
%202020/Keeppower%2021700%205000mAh%20P5150TC%20(White-Blue)%202020-info.png)
This is a 21700 cell with build-in USB-C charger, the cell is a protected high capacity cell.
%202020/DSC_4321.jpg)
%202020/DSC_4324.jpg)
%202020/DSC_4325.jpg)
%202020/DSC_4326.jpg)
%202020/DSC_4327.jpg)
%202020/DSC_4328.jpg)
%202020/DSC_4329.jpg)
%202020/Keeppower%2021700%205000mAh%20P5150TC%20(White-Blue)%202020-Capacity.png)
The two cells match just about perfect and can easily deliver the rated 8A.
%202020/Keeppower%2021700%205000mAh%20P5150TC%20(White-Blue)%202020-Temp-7.0.png)
%202020/Keeppower%2021700%205000mAh%20P5150TC%20(White-Blue)%202020-Temp-10.0.png)
%202020/Keeppower%2021700%205000mAh%20P5150TC%20(White-Blue)%202020-CapacityTimeHours.png)
%202020/Keeppower%2021700%205000mAh%20P5150TC%20(White-Blue)%202020-CapacityTime.png)
%202020/Keeppower%2021700%205000mAh%20P5150TC%20(White-Blue)%202020-Energy.png)
%202020/Keeppower%2021700%205000mAh%20P5150TC%20(White-Blue)%202020-PowerLoadTime.png)
%202020/Keeppower%2021700%205000mAh%20P5150TC%20(White-Blue)%202020-TripCurrent.png)
%202020/Keeppower%2021700%205000mAh%20P5150TC%20(White-Blue)%202020-Charge.png)
The USB charging uses a switching regulator to keep the heat down, I measured about 10°C temperature increase at the front of the cell during charge.
The USB-C input do not follow any protocols, except signalling it needs power.
Conclusion
It is a good battery and the USB charging means it can share charger with a mobile phone, this is very practical when traveling or when having only a few LiIon batteries. Only caveat is that the battery is considerable longer than a standard 21700 cell.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
