Protection Circuit (Against overcharge, over discharge, over current and short-circuit.)
4.2 volts max voltage and 3.7 volts nominal voltage
Over 500 charge-discharge cycles
This is a 26650 with a high capacity marking and even higher capacity than marked.
The battery has a lot of capacity, but the cells does not track at higher currents, making it difficult to use them in series configuration.
The battery is best used at 7A or lower load.
The battery has a protection, but the trip point is too high.
Conclusion
The battery has an impressive capacity and work fairly well up to 7A load.
The over current protection is placed at to high value and will not protect the battery from overload. I suppose that over discharge and over charge will work.
Thanks for the review HKJ,great news about the capacity but disappointing about the protection circuit.It's a false sense of security to have a protected cell that will not trip,and decieves the buyer.I think Keeppower should recall the battery until the protection is fixed or list it as unprotected.Thanks for this helpful review.
HKJ, I bought a black, protected, 4000mAH 26650 (edit) King Kong, from Mountain Electronics, but the one I received is labelled 4500mAH, do you have a theory on that?
Thanks for the informative review HKJ!
I have bookmarked your website lygte way before I joined this forums and it was a surprise seeing your website in your signature!
Really appreciate all your effort in doing awesome and informative reviews
