Keeppower IMR18350 (Black)
/DSC_4340.jpg)
Official specifications:
Product Name: KP IMR 18350 3.7V Electronic Cigarette Battery
Brand: Keeppower
Model: 18350
Typical Capacity: 750mAh
Normal Voltage: 3.7V
Charge Method: constant voltage with limited current
Standard Charge Current: 500mA
Fast Charge Current: 700mA
Max. Plus Discharge Current: 15.0A
Max. Constant Discharge Current: 8.0A
Full Charged Voltage: 4.2V
Discharge Cut Off Voltage: 2.5V
Weight: 21.0±0.5g
/Keeppower%20IMR18350%20(Black)-info.png)
Keeppower usual has good cells under their wrapper, do this high current 18350 cells I bought from banggood live up to that?
/DSC_4339.jpg)
/DSC_4342.jpg)
/DSC_4343.jpg)
/DSC_4344.jpg)
/Keeppower%20IMR18350%20(Black)-Capacity.png)
Up to 7A the curves has good tracking, the 10A is a bit compromised and 15A is way to high. This looks very reasonable for a 8A cell.
/Keeppower%20IMR18350%20(Black)-Temp-7.0.png)
A 15C temperature raise, this is perfectly acceptable.
/Keeppower%20IMR18350%20(Black)-Temp-10.0.png)
The 20C raise is not a proble either.
/Keeppower%20IMR18350%20(Black)-Temp-15.0.png)
At 15A the cell collapses too fast to get hot (But it I had keep the load on it likely have given problems).
/Keeppower%20IMR18350%20(Black)-CapacityTimeHours.png)
/Keeppower%20IMR18350%20(Black)-CapacityTime.png)
/Keeppower%20IMR18350%20(Black)-Energy.png)
/Keeppower%20IMR18350%20(Black)-PowerLoadTime.png)
/Keeppower%20IMR18350%20(Black)-TripCurrent.png)
/Keeppower%20IMR18350%20(Black)-Charge.png)
Conclusion
The cell has good high current performance, this also means the capacity is not in top.
Notes and links
This test was done while I was adjusting how to record traces from my 4-terminal system, that is the reason for the tail on one curve and not one the other in the 10A trace.
Comparison to other LiIon batteries
