Keeppower IMR18650 NH1835 3500mAh (Black) 2016
%202016/DSC_7310.jpg)
Official specifications:
Nominal capacity: 3500mAh
Minimum capacity: 3400mAh
Nominal voltage: 3.70V
Charge voltage: 4.20V 0/-0.05V
Standard discharge cut-off: 2.50V
Standard charge current: 1000mA
Charge current cut-off: 50mA
Max. Constant discharge current: 10A
Max. Pulse discharge current: 20A
%202016/Keeppower%20IMR18650%20NH1835%203500mAh%20(Black)%202016-info.png)
%202016/DSC_7308.jpg)
%202016/DSC_7312.jpg)
%202016/DSC_7313.jpg)
%202016/DSC_7314.jpg)
%202016/Keeppower%20IMR18650%20NH1835%203500mAh%20(Black)%202016-Capacity.png)
The discharge curves looks very good with nice tracking, except the 20A curve, the battery did blow a fuse during that discharge.
This also means this test will be missing a few curves.
%202016/Keeppower%20IMR18650%20NH1835%203500mAh%20(Black)%202016-CapacityTimeHours.png)
%202016/Keeppower%20IMR18650%20NH1835%203500mAh%20(Black)%202016-CapacityTime.png)
%202016/Keeppower%20IMR18650%20NH1835%203500mAh%20(Black)%202016-Energy.png)
%202016/Keeppower%20IMR18650%20NH1835%203500mAh%20(Black)%202016-Charge.png)
Conclusion
The battery is very good, but cannot sustain 20A discharge, this matches the specifications.
Notes and links
The batteries was supplied by Keeppower for review.
Compare to 18650 and other batteries
