Keeppower IMR20700 4250mAh UH2042 (Black) 2017
%202017/DSC_2652.jpg)
Official specifications:
Part No.: UH2042
High Drain 20700 Li-ion Rechargeable Battery
Minimum Capacity: 4050mAh
Typical Capacity: 4250mAh
Normal Voltage: 3.7V
Standard Continuous Charging Current: 1000mA
Maximum Continuous Charging Current: 2000mA
Maximum Continuous Discharging Current: 15A
Maximum Pulse Discharging Current: 30A
4.2V full charged voltage and 2.5V discharge cut off voltage
High charge and discharge currents reduce cycle life
%202017/Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-info.png)
A high capacity cell in the new 20700 form factor.
%202017/DSC_2651.jpg)
%202017/DSC_2654.jpg)
%202017/DSC_2655.jpg)
%202017/DSC_2656.jpg)
%202017/Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-Capacity.png)
The discharge curves tracks fine, the capacity is present at low load, but at higher loads the cell has a bit less capacity.
%202017/Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-Temp-10.0.png)
%202017/Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-Temp-15.0.png)
At 15A the cell gets rather warm.
%202017/Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-Temp-20.0.png)
At 20A it gets too hot and i had to stop.
%202017/Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-CapacityTimeHours.png)
%202017/Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-CapacityTime.png)
%202017/Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-Energy.png)
%202017/Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-PowerLoadTime.png)
%202017/Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-TripCurrent.png)
%202017/Keeppower%20IMR20700%204250mAh%20UH2042%20(Black)%202017-Charge.png)
Conclusion
This looks like a very good cell with good capacity for its size.
Notes and links
The battery was supplied by Keeppower for review.
Compare to 18650 and other batteries
