Keeppower INR21700 3000mAh NM2130 (Black) 2019
%202019/DSC_6878.jpg)
Official specifications:
Capacity min.: 2900mAh
Capacity typ.: 3000mAh
Nominal voltage: 3.70V
Charge voltage: 4.20+/-0.05V
Standard discharge cut-off voltage: 2.50V
Standard charge current: 1500mA
Charge termination current: 150mA
Max. continuous discharge current: 35A
%202019/Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-info.png)
This is a high current 21700 battery with fairly low capacity for its size.
%202019/DSC_6877.jpg)
%202019/DSC_6880.jpg)
%202019/DSC_6881.jpg)
%202019/DSC_6882.jpg)
%202019/Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-Capacity.png)
This discharge curves matches very fine and capacity is basically the same at any current.
%202019/Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-Temp-20.0.png)
%202019/Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-Temp-30.0.png)
%202019/Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-CapacityTimeHours.png)
%202019/Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-CapacityTime.png)
%202019/Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-Energy.png)
%202019/Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-PowerLoadTime.png)
%202019/Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-TripCurrent.png)
%202019/Keeppower%20INR21700%203000mAh%20NM2130%20(Black)%202019-Charge.png)
Conclusion
This is good battery when needing high current.
Notes and links
The battery was supplied by Keeppower for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
