Test/Review of Kinoko IMR14500 750mAh (Gray)
Official specifications:
  • Brand: Kinoko
  • Size: 14500
  • Model: 14500 IMR
  • Type: Li-Mn
  • Rated Capacity: 750mAh
  • Nominal Voltage: 3.7V
  • Lowest Discharge Voltage: 2.50V
  • Peak Voltage: 4.2V
  • Standard Charge: CC/CV ( max. charging rate 1.5A )
  • Dimensions: 14.15mmX48.85mm
  • Weight: 25g
  • Rechargable: Yes
  • Protected: Not Required for Li-Mn chemistry
  • Chemistry: Lithium Manganese Dioxide Li-Mn02
  • Style: Button top (may require a magnetic spacer)
  • Discharge temperature range : -20°C--45°C
  • Charger temperature range : 0°C--45°C
  • Storge: 1year : -20°C--25°C, 3 months : -20°C—45°C, 1 month : -20°C—60°C
A LiIon IMR battery in AA size.
The high current capabilty is good on these cells.
The two cells does not have exactly the same capacity and without protection this makes them best for single cell usage.
Conclusion
This IMR cells has a good performance, I will rate it as a acceptable cell.
Notes and links
The batteries was supplied by Illuminationsupply for review.
Comparison to other LiIon batteries
Thanks for the test. The timing is perfect. I need a higher current 14500 and I only have one good 14500, and that doesn't even do 3A. Good advertising for IS too.
It seems others are silently reading this review. The 18350 version is already sold out.
Inventory was inaccurate. I usually reduce the number we actually have online to make a buffer.
