LFP18650E 1500mAh LiFePO4 (Violet)
/DSC_2870.jpg)
Official specifications:
Voltage: 3.2V (limit voltage:2.0-3.65V)
Capacity:1400-1500mah
Cycle times: about 800
Brand new Lithium Ion batteries,used for laser pointer,torch flashlight,and other electronics.
Size:18650 battery (18*65mm)
Max discharge current: 2-3C (Continous discharge 1-2C)
Max charge current: 1C
/LFP18650%201500mAh%20LiFePO4%20(Violet)-info.png)
This is LiFePO4 batteries, they have lower voltage and another discharge characteristic than the usual LiIon batteries.
/DSC_2869.jpg)
/DSC_2872.jpg)
/DSC_2874.jpg)
/LFP18650%201500mAh%20LiFePO4%20(Violet)-Capacity.png)
These types of LiIon have a very flat discharge and considerable less capacity than normal LiIon batteries.
/LFP18650%201500mAh%20LiFePO4%20(Violet)-Temp-7.0.png)
/LFP18650%201500mAh%20LiFePO4%20(Violet)-Temp-10.0.png)
/LFP18650%201500mAh%20LiFePO4%20(Violet)-Temp-15.0.png)
/LFP18650%201500mAh%20LiFePO4%20(Violet)-CapacityTimeHours.png)
/LFP18650%201500mAh%20LiFePO4%20(Violet)-CapacityTime.png)
/LFP18650%201500mAh%20LiFePO4%20(Violet)-Energy.png)
/LFP18650%201500mAh%20LiFePO4%20(Violet)-PowerLoadTime.png)
/LFP18650%201500mAh%20LiFePO4%20(Violet)-TripCurrent.png)
/LFP18650%201500mAh%20LiFePO4%20(Violet)-Charge.png)
Conclusion
These batteries looks like good LiFePO4 cell with rated capacity.
Notes and links
Compare to 18650 and other batteries
