LG 18650 B4 2600mAh (Gray)
/DSC_2569.jpg)
Official specifications:
Nominal capacity: 2600mAh
Minimum capacity: 2500mAh
Nominal voltage: 3.6V
Standard charge: 0.5C (1250mA), 4.2V, cut-off at 50mA
Max. charge voltage: 4.2V
Max. charge current: 1.0C (2500mA)
Standard discharge: 0.2C (500mA)
End voltage: 2.75V
Max. discharge current: –20 ~ 5°C: 0.5C (1250mA), 5 ~ 45°C: 2.0C (5000mA), 45 ~ 60°C: 1.5C (3750mA)
Weight: Max. 48.0g
Operating temperature: Charge 0 45°C, Discharge: –20 60°C
Storage temperature (Shipping state): 1 month: –20 ~ 60°C, 3 months: –30 45°C, 1 year: –20 20°C
Cycle life: 300 cycles to 80% (0.5C charge/discharge current)
/LG%2018650%20B4%202600mAh%20(Gray)-info.png)
This is a fairly old cell, datasheet is from 2010. It might be possible to get cheap or find in battery packs.
/DSC_2568.jpg)
/DSC_2571.jpg)
/DSC_2572.jpg)
/DSC_2573.jpg)
/LG%2018650%20B4%202600mAh%20(Gray)-Capacity.png)
The discharge curves tracks fine and had constant capacity when staying within allowed load current.
/LG%2018650%20B4%202600mAh%20(Gray)-CapacityTimeHours.png)
/LG%2018650%20B4%202600mAh%20(Gray)-CapacityTime.png)
/LG%2018650%20B4%202600mAh%20(Gray)-Energy.png)
/LG%2018650%20B4%202600mAh%20(Gray)-PowerLoadTime.png)
/LG%2018650%20B4%202600mAh%20(Gray)-TripCurrent.png)
/LG%2018650%20B4%202600mAh%20(Gray)-Charge.png)
Conclusion
It was a very good cell some years ago, but compared to new cell types the performance is not very impressive.
The battery will work perfectly for a few amperes load, but is not for high current purpose.
Notes and links
Compare to 18650 and other batteries
