just look in post #14
HKJ
Thanks again for your time and effort, very much appreciated.
Is it possible, that the lable on the backside is wrong?
In the second line of āOutput:ā it says āDC 4.65V 500mA/1000mAā. Shouldnāt it be 3.65V for Li-Fe?
http://freedailydeals.org/wp-content/uploads/2016/01/freedailydeals-LiitoKala-1.jpg
That label is wrong, 3.65V is more correct.
Thank you very much for thi review, now I will buy one of this, finally ![]()
Just a silly question (please donāt hate me) : are you plain to do a tear down to see if LitoKala 100 and Skilhunt M1 have the same part inside?
Probably they are not different, so why the Skilhunt charger cost double?
I seldom tear down chargers.
Probably due to different business strategies, one dealer sells as cheap as possible, the other dealer tries to maintain some quality.
I do not always go for the cheapest deal, I know it cost money to write a manual and assure that you products have a certain quality.
HKJ:
Thanks for getting around so quickly to review this charger.
I was surprised that it works so well as a 1A power bank.
Iām glad I picked up a couple when they were on sale earlier. smile
Thanx again, well done :aOK:
I have the tendency of leaving cells fully charged and store them for later use. I wonder if the .05V higher termination could lead to quicker deterioration?
I have two of those chargers and when I measure the voltage right after charging I get 4.19 or 4.20 Volts. Canāt confirm the high voltage.
I ordered mine on the 29th of January and I showed up today! Wow that is fast! I love it, wish I had ordered a couple of them.
You have to measure just before it stops charging.
I bought the charger and happy to see the review.
Thanks!
Thanks for one more great review HKJ. ![]()
Thanks for the review HKJ.
What happens to the lights when a battery is fully charged?
lights stop blinking
Thatās what I thought, thanks.
Just checked 4 chargers, measured within 30 minutes of charge termination, 4.19, 4.20, 4.21, 4.22. Very satisfied with these chargers and they all worked.
The lights stop blinking with all Blue indicators solid, then eventually all lights go out⦠What does this indicate?
I checked and there is no current going to the battery when the blue lights are solid. I donāt know why they turn off after some time.
I have some issues with flat top cells. Some of them donāt make a good contact. Thatās the only downside I found so far. Well the second one is that you canāt give this charger to anybody because there is a risk that they will press the button and charge to 4,35v a standard battery⦠I wonder if there is a risk of fire in that caseā¦
