Lumintop 18650 3400mAh (White) LM34
/DSC_2935.jpg)
Official specifications:
Rated Capacity (Minimum): 3200mAh
Nominal Capacity (Typical): 3350mAh
Nominal voltage: 3.6V
Discharge end voltage: 2.5V
Charging current (std): 1.625A
Charging voltage: 4.20 +/-0.03V
Continuous discharging current (Max): 4.875A
Internal resistance: <=48mOhm
Weight: <47.5g
Operating temperature charge: 0°C ~ 45°C, discharge –20°C ~ 60°C
Storing conditions: less than 1 month: –20°C 50°C, less than 3 months: –20°C 40°C, less than 1 year: –20°C ~ 20°C
/Lumintop%2018650%203400mAh%20(White)-info.png)
Lumintop has taken a well known 18650 cell and added protection.
/DSC_2934.jpg)
/DSC_2937.jpg)
/DSC_2938.jpg)
/DSC_2939.jpg)
/DSC_2940.jpg)
/Lumintop%2018650%203400mAh%20(White)-Capacity.png)
These discharge curves match perfectly. The overcurrent protection kicks in during the 5A discharge (fits nicely with rated current).
/Lumintop%2018650%203400mAh%20(White)-Temp-2.0.png)
/Lumintop%2018650%203400mAh%20(White)-Temp-3.0.png)
/Lumintop%2018650%203400mAh%20(White)-Temp-5.0.png)
No temperature problems with these cells and currents.
/Lumintop%2018650%203400mAh%20(White)-CapacityTimeHours.png)
/Lumintop%2018650%203400mAh%20(White)-CapacityTime.png)
/Lumintop%2018650%203400mAh%20(White)-Energy.png)
/Lumintop%2018650%203400mAh%20(White)-PowerLoadTime.png)
/Lumintop%2018650%203400mAh%20(White)-TripCurrent.png)
/Lumintop%2018650%203400mAh%20(White)-Charge.png)
Conclusion
Adding protection to a very good cell will usual make a very good battery, as is the case here.
The protection is placed at the top of the battery!
Notes and links
The batteries was supplied by Lumintop for a review.
Compare to 18650 and other batteries
