Molicel INR18650-P28A 2800mAh (Gray)
/DSC_5287.jpg)
Official specifications:
Typical capacity 2800mAh
Minimum capacity: 2600mAh
Nominal voltage: 3.6V
Standard charge current: 2.8A
Maximum charge current: 6A
Discharge cut-off voltage: 2.5V
Charge cut-off voltage: 4.2V
Maximum discharge current: 35A
Internal resistance: 20mOhm
Internal resistance DC: 20mOhm (10A/1s)
Ambient temperature: Charge: 0°C ~ 60°C, Discharge: –40°C ~ 60°C
Typical cycle life: 400 cycles to 80% at 20A discharge.
/Molicel%20INR18650-P28A%202800mAh%20(Gray)-info.png)
This is a high current 18650 cell with fairly good capacity.
/DSC_5289.jpg)
/DSC_5290.jpg)
/DSC_5291.jpg)
/Molicel%20INR18650-P28A%202800mAh%20(Gray)-Capacity.png)
The two cells tracks very nicely, at 30A the battery got hot and I stopped the test before the battery was empty.
/Molicel%20INR18650-P28A%202800mAh%20(Gray)-Temp-15.0.png)
/Molicel%20INR18650-P28A%202800mAh%20(Gray)-Temp-20.0.png)
/Molicel%20INR18650-P28A%202800mAh%20(Gray)-Temp-30.0.png)
/Molicel%20INR18650-P28A%202800mAh%20(Gray)-CapacityTimeHours.png)
/Molicel%20INR18650-P28A%202800mAh%20(Gray)-CapacityTime.png)
/Molicel%20INR18650-P28A%202800mAh%20(Gray)-Energy.png)
/Molicel%20INR18650-P28A%202800mAh%20(Gray)-PowerLoadTime.png)
/Molicel%20INR18650-P28A%202800mAh%20(Gray)-TripCurrent.png)
/Molicel%20INR18650-P28A%202800mAh%20(Gray)-Charge.png)
Conclusion
A good high current cell and not that different from the P26A
Notes and links
The batteries was supplied by a reader review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
