Molicel INR20700A 3000mAh (Gray)
/DSC_5270.jpg)
Official specifications:
Rated typical capacity: 3000mAh
Rated minimum capacity: 2800mAh
Nominal voltage: 3.6V
Maximum charge current: 3A
End of charge voltage: 4.20V +/-0.05V
Maximum discharge current: 35A (Cycle life is reduced at high rates)
End of discharge voltage: 2.5V
Typical impedance: <20mOhm AC 1kHz
Cycle life: 500 cycles at 3A charge and 10A discharge for 80%
Operating temperature: Charging: 0°C ~ 60°C, Discharging: –40°C ~ 60°C
Storage temperature: <35°C, recommended <23°C for long term.
/Molicel%20INR20700A%203000mAh%20(Gray)-info.png)
This is a high current 20700 cell.
/DSC_5269.jpg)
/DSC_5272.jpg)
/DSC_5273.jpg)
/DSC_5274.jpg)
/Molicel%20INR20700A%203000mAh%20(Gray)-Capacity.png)
The two cells tracks nearly perfectly, at the 30A discharge I had to stop due to temperature, but the cell do not look overloaded on the discharge curve.
/Molicel%20INR20700A%203000mAh%20(Gray)-Temp-15.0.png)
/Molicel%20INR20700A%203000mAh%20(Gray)-Temp-20.0.png)
/Molicel%20INR20700A%203000mAh%20(Gray)-Temp-30.0.png)
/Molicel%20INR20700A%203000mAh%20(Gray)-CapacityTimeHours.png)
/Molicel%20INR20700A%203000mAh%20(Gray)-CapacityTime.png)
/Molicel%20INR20700A%203000mAh%20(Gray)-Energy.png)
/Molicel%20INR20700A%203000mAh%20(Gray)-PowerLoadTime.png)
/Molicel%20INR20700A%203000mAh%20(Gray)-TripCurrent.png)
/Molicel%20INR20700A%203000mAh%20(Gray)-Charge.png)
Conclusion
Very good battery for up to about 30A, at the high current the battery may need a rest during discharge to cool down a bit.
Notes and links
The batteries was supplied by N-Power Energy for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
