MPIFR 18650 1500mAh (Gray)
/DSC_3472.jpg)
Official specifications:
Type: IFR MUB18650 1500mAh
Nominal Capacity: 1500mAh
Nominal Voltage: 3.2V
Size: Diameter 18±0.2mm X Height 65±0.5mm
Net Weight: 40g
Max charge voltage: 3.70V
Max continuous charge current: 1500mA
Max continuous discharge current: 3000mA
Discharge cut-off voltage: 2.0V
Internal impedance: (20±2°C) <60mOhm (50% charged)
Operation temperature: Discharge: –20°C ~ 70°C, Charge: 0°C ~ 70°C
Cycles: above 1000 (0.2C to 3.7V till the charge current is less than 0.01C. 0.2C to 2.0V when discharge)
/MPIFR%2018650%201500mAh%20(Gray)-info.png)
A LiFePO4 18650 cell, the capacity is fairly limited, but the lifetime rating is good.
/DSC_3471.jpg)
/DSC_3474.jpg)
/DSC_3475.jpg)
/DSC_3476.jpg)
/MPIFR%2018650%201500mAh%20(Gray)-Capacity.png)
The discharge curves match fine and as usual for LiFePO4 the discharge voltage is very constant. The batteries are only rated for 3A and they handle that easily.
/MPIFR%2018650%201500mAh%20(Gray)-Temp-7.0.png)
/MPIFR%2018650%201500mAh%20(Gray)-Temp-10.0.png)
/MPIFR%2018650%201500mAh%20(Gray)-Temp-15.0.png)
/MPIFR%2018650%201500mAh%20(Gray)-CapacityTimeHours.png)
/MPIFR%2018650%201500mAh%20(Gray)-CapacityTime.png)
/MPIFR%2018650%201500mAh%20(Gray)-Energy.png)
/MPIFR%2018650%201500mAh%20(Gray)-PowerLoadTime.png)
/MPIFR%2018650%201500mAh%20(Gray)-TripCurrent.png)
/MPIFR%2018650%201500mAh%20(Gray)-Charge.png)
Conclusion
This battery works fine, but capacity is limited. The 3A rating looks rather conservative.
Notes and links
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
