MXJO IMR18350 700mAh (Yellow)
/DSC_3824.jpg)
Official specifications:
Capacity: 700mAh
Nominal Voltage: 3.7V
Max. Continuous Discharge Current: 10.5A
Max. Discharge Current: 14A
Dimensions: 35.5*18.5MM (+/-0.05)mm
Operating Discharge Temperature: –10 to 60 Degrees Celsius
Standard Charge: CC/CV 0.5A, 4.20 ± 0.05 V
Cycle Life: > 300 cycles
Weight: 28g
/MXJO%20IMR18350%20700mAh%20(Yellow)-info.png)
This is a high current 18350 cell
/DSC_3823.jpg)
/DSC_3826.jpg)
/DSC_3827.jpg)
/DSC_3828.jpg)
/MXJO%20IMR18350%20700mAh%20(Yellow)-Capacity.png)
The discharge curves looks good with the cell tracking nicely and nearly constant capacity. The 15A discharge was way above the capability of the cell.
/MXJO%20IMR18350%20700mAh%20(Yellow)-Temp-7.0.png)
/MXJO%20IMR18350%20700mAh%20(Yellow)-Temp-10.0.png)
/MXJO%20IMR18350%20700mAh%20(Yellow)-Temp-15.0.png)
The cells do not get too hot for this discharge current because the time is very short (Between 2 and 3 minutes).
The peak temperature registered is 40°C above ambient, this means around 65 to 70°C on the outside.
/MXJO%20IMR18350%20700mAh%20(Yellow)-CapacityTimeHours.png)
/MXJO%20IMR18350%20700mAh%20(Yellow)-CapacityTime.png)
/MXJO%20IMR18350%20700mAh%20(Yellow)-Energy.png)
/MXJO%20IMR18350%20700mAh%20(Yellow)-PowerLoadTime.png)
/MXJO%20IMR18350%20700mAh%20(Yellow)-TripCurrent.png)
/MXJO%20IMR18350%20700mAh%20(Yellow)-Charge.png)
Conclusion
These cells has a good high current performance performance, but capacity is on the low side due to the high current ability.
It looks like a good cell.
Notes and links
Comparison to other LiIon batteries
